bye #2
  • bye #2
    Im getting some problems with unpluigging my IDE drives.
    Do i only have to unplug the IDE cable from CD/DVD ROM?
    The one that's white and thin. Because i unplugged it and Mounted image but still my games doesn't work.
    Can any1 help me
    Thx
    Originally Posted by NetSoerfer
    Did you use the CD-key that came with the CD you made the image from? You cannot use downloaded mds-files with your own key for StarForce 3.6-protected games anymore as the CD-key is stored in those mds-files.
    1 Question.
    I downloaded Worms 4 Mayhem from 1 server. it didn't had any images on it. How could i play this then or how could i make an image without cd-key. If i take any image and try to remake it with Alcohol 120% would it help. And i couldnt download different Mds files if i tried to mount it it said Unable to mount image.File not accessable with every mds there was.
