is easy u guys just folow this
firs of all if u dont have the images make them with Alcohol 120%
then install the game with DEamon Tools 4 when finish restart ur pc and switch off unplugged all ur IDE CABLES and start ur pc mount cd1 in deamontools and start the game is the only way believe me it works 100% .....otherwise try to look here
i hope it helps...
i hope it helps...
