daemon tools 4.03he - does this support the daa image format? if it does how do i enable that? if it doesnt is it possible to upgrade it to support that format? or is there any other virtual drive program i could use that supports .daa files? im using power iso but i cant seem to run Civilization 4 (iv) after it installed i ran it and it came up with a window saying (cannot locate the cd-rom) please insert the correct cd-rom, select ok and restart application.
(a virtual drive program with .daa support and safe disc emulation would be nice it might work then)
thanks in advance 4 the help
