25 to life
  • 25 to life
    Does anyone know how to work it. It uses securom v7 and i used all the tools that are supposed to stop it from blacklisting can anyone help me???
    First and most important question is what program did you use to make the image and what settings did you use in that program? Because if the image isn't good, then nothing we can recommend will make it work from the virtual drive.
      i didnt make a image i download it from the net
