Okay, so I aquired the installation CD and all three disks isos of Final Fantasy VII PC. I mounted the install cd and everything went smooth and installed properlly. So I unmounted it and mounted the disk 1 ISO. When I click on the FFVII logo to start the game, my screen goes black for a sec then goes back to the window. Any suggestions?
Iso-Images won't work. Scan you CDs with Aray-Scanner to find out which copyprotection is used ( or take a look here -> Database ). Then recreate your images using Alcohol 120 % or maybe CloneCD or Blindwrite.
If that does not solve your issue it's maybe a compatibility issue with XP ( assuming you are using XP? ). Take a look here or google for "final fantasy 7 xp"
