i was starting to think that all troubles are somehow related to x64 windows, but now i see some people run EAW on x64 without any problems. maybe it's game image-dependent? had anyone success running game from BWT images of cd-version (MIRROR release)? another strange thing - i still cant run antisecurom. it launches, then quits without any message. sweaw.exe, at which i point, doesnt even appear in processes list. but if i run antisecurom from zip archive without extracting - it launches sweaw.exe but then i get "emulator detected" message...
FYI, just some info on what I tried and my setup.. including what I did to get it to work.
System:
XP pro (32bit)
Sony DVD-RW
DT4
CureRom 1.3
Images tried: (all obtained from newsgroups, I did not image it myself)
DVD image
2 cd image cue/bin
2 cd image *.bwt
First two images mentioned above, nothing worked.. I tried every method mentioned in this thread. The DVD worked once for some odd reason and never again.
The last image, *.bwt. Worked perfectly.. I only used DT4 and CureRom 1.3 AND I even left my Sony DVD-RW pluged in and powered. Works everytime...
So, If you have not tried already.. try other images... If you can get to this error "Originial disc could not be found or authenticated" then, what people wrote is correct.. it is your image... other errors are indeed the method use to bypass checks...but if your method gets you the error above, then all you need is a good image... so it seems.
