some posts from SW-thread ...
  • some posts from SW-thread ...
    Nothing worked until I got the *.bwt img. All other img's failed.. cd's and DVD.. I used CureRom and DT4 that is it... and I left my DVD-RW plugged in and powered.. which is a Sony drive...
    Every other image failed using every method mentioned in this thread...as soon as I got the BWT image.. it was gravy...
    Well, I have gotten then game to run for approximatly 5-10 minutes, Both cd and DVD version. using all kinds of methods. Problem is, I keep getting an Exception Error and it crashes the game. No idea why, just does. I've had this happen in the 1.2 Patch aswell . Guess I'll wait for a cracked copy to come out and see if that works properly.
      Originally Posted by Muner
      Ok after a lot of trouble I have finaly managed to get it up and running. I have gone through 3 images and I can now say that if you get the "Originial disc could not be found or authenticated" then it is a bad image. I am now using a mini image mounted manually in DT4.0.3 x64 and starting it with AntiSecuRom
      would you be able to upload your mini image, i get this error with the original DVD!!!!!!!! i've tried make 10 or so images and the best one will start about 1 in 10.
        I been reading and tried everything but i may have found the solution to the problem, first i got the BW Clone Torrent of the Game, which oddly wasnt the whole game, and then got the DVD version and installed that way, been tring for hours, then i though why not try the cd i burned from the BW Clone, well after i insert the supposed second cd it gave me a new meesage "Inserted wrong CD, Insert Correct one" so i insert my MDS burnt one and walaa it works.
