1) Download Empire at War CureRom profile from GCW
2) Download the latest CureRom software and install it.
3) If you have Alcohol 120% or Daemon tools on your computer, unmount all the images.
4) After install the latest CureRom software, create a profiles folder C:\Program Files\CureROM\Profiles. And copy mir-eaw.crp file into "profiles" folder.
5) Run CureRom software to create shortcut.
6) Check "Open an existing CureRom profile" in profile Options.
7) Application : C:\Program Files\LucasArts\Star Wars Empire at War\GameData\sweaw.exe
8) Checked CureROM Anti-Blacklist Measures (Enabled).
9) Select "Use Daemon Tools to mount my backup images" for Image Mounting Software.
10) With Backup Image: point to backup image (mds file).
11) Select 15seconds for backup image to load.
12) In Shortcut settings, select create shortcut on the desktop, click "next".
13) Click "save" and click "finish".
Good luck!!!!
always the same message....
"A required security module can not be activated. This program can not be executed."
