Hej, I got a problem with this game. Curerom just doesn't seem to work or something. I use daemon tools en made an alternative exe by using curerom. When i start it it waits 3 seconds for loading and then it still says "Virtual rom detected."
im using curerom too i use curerom pro 1.3.1 it didnt work i put the exe at this programm and the image i dont know what to do at the and cames always the saym think original disc could not be found
what should i o how can i play this game hope u can help
I am having trouble with this one too, although I'm new to CureROM so I might just be mucking it up somehow. It tells me that the original disk isn't in the drive or can't be authenticated. Tried messing (technical term, obviously) with the settings and nothing has worked so far.
Works for me , loaded the blindwrite image into DT4.03,
started securom loader 1.1 choosed the .Exe file from the directory where you installed the game, waited a few seconds then started game, works perfect.
Mount the image and use CureROM or the Securom Loader from the download section for antiblacklisting.
You need an good image, that means you need an image created with Alcohol 120% (or Blindwrite). The images needs to have the DPM-Info, therefore it's necessary to enable the data position measurement in the reading seetings during the image creating process.
it didnt work, i tried mounting the image made by Alcohol with Daemon Tools. They kept saying its invalid mount image. Whats wrong? I also tried with Curerom and other suggestions, it still didnt seem to work.
