I actually got this game to work by following these instructions (the ones in the nfo file):
1. You must have Windows XP with SP2 in order of playing
2. IDE PCI Controller Drivers MUST be OS STANDARD IDE PCI Drivers.
3. Unpack file sfcure01 that's in tools.rar and launch file !setup.bat through MS-Dos Prompt and reboot your box.
4. If u have AMD64, then use sfcure_x64 that works same way as the other.
5. Check if all option of Daemon or Alcohol are activated especially RMPS option.
6. Mount image using Alcohol 120% or Daemon and install the game.
7. Once installation is complete, launch sfdrup.exe to update StarForce3 drivers and reboot the box.
8. Launch through MS-Dos Prompt the file !start.bat that's in the unpacked file sfcure01.
9. Unpack file sfn.rar e launch sfn.exe (StarForce Nightmare 1.12).
10 Select in this order "Disable node" , "Disable CD" , "Disable node" , and the IDE channel you use for real CD/DVD units (Pr. Slave , Sc. Master o Sc.Slave ), depending on how your IDE units are connected.
11. Launch the game and use this serial: FFMGU-HA34Y-V8ABF-VUN3Y-SCTRP .
12. Play.
I also disconnected my DVD ROM drives power cable before mounting and installing the game and I have left it unplugged ever since (I never use it anyway).
Once the above setps are done I can run the game at any time(it takes about 4 clicks of the mouse).
Good game BTW!
Any questions, feel free to ask.
Cheers.
12. Play.
Good game BTW!
Cheers.
