ok guys, just got done downloading this and i had this problem
but i have foudn the solution.
This is how i got it to work. Mounted the image with DT4 (using curerom).
when the app launched i closed the window, then used securom loader v1.0 (available in the downloads section) and used it to load the sweaw.exe file from the GameData folder.
it proceeded to load, and works evertime now (using the above method)
no thanks needed, i know im alreay godlike
