Ok everyone, none of the things helped me here, but i figured it out myself.
1st you need: Daemon Tools 4, Curerom1.3.1, Starwars CD1 Burnt with blind write as in instructions.
In profiles, settings of curerom remove all the checkmarks, then select suspend autoplay, as for where it asks what u want to use, alcohol, daemon tools or nothing, select NOTHING (or something like that)
That will create a screenshot. Download this image
http://dl23cg.rapidshare.de/files/13757736/419837661/SWEAT_MINI_IMAGE.rar
And mount it with d-tools, MAKE SURE THAT ALL OPTIONS AND EMULATIONS ARE DISABLED.
once again, configure you curerom just to sceenshot, you might get confused why selecting nothing how can it use d-tools, but dont worry about it, mount that image with dtools, making sure that all your cdroms are disabled.
After you made sure once again.
1. Cdroms disables
2. mini image mouned with d-tools no emulation and options enabled.
3. configure curerom 1.3.1,(curerom options IN bottom left) in options remove all checkmarks, select your sweat.exe, select a choice "I DO NOT WANT TO USE ANY VIRTUAL CDROM SOFTWARE" making sure autoplay is disabled.
4. Finish up work on curerom.
5. Double click created shortcut file and the game should work.
1. Cdroms disables
