bye you, too
  • bye you, too
    Originally Posted by rip_pit
    See the post #11 in the following thread. It talk about commandos S.F.
    http://www.daemon-tools.cc/dtcc/show...2715#post52715
    sYk0, i did everything right....
    I selected Create a new CureROM profile and clicked next
    in the application box i clicked on the browse folder and
    selected the commandos S.F. exe file
    then I clicked on next again
    On image mounting i selected "use daemon tools to mount my backup images" and below that on the Backup Image option i select the following file "COMMANDOS_SF.mds"
    at the shortcut settings i clicked next again
    and at last i selected Save, finish.
    then I clicked the icon on my desktop ( called CommXPC.exe )
    So daemon tools mounts the image and after a moment curerom gives me the following message:
    '' Original disc could not be found or authenticated. ''
    Does curerom work with Commandos S.F. or i should try another 'hide devices' program?
    pidr1nhu, how did you create your image (program/settings)?
      Analcobra, it was already created...not by me...
      I unrared ( extracted ) it from 80 rar files...and two files appeared
      COMMANDOS_SF.mdf
      COMMANDOS_SF.mds
      i just mounted the image using the mds file....exactly how its on the tutorial...
      any suggestion?
      regards!
        Originally Posted by FnF
        Well, I reinstalled DT403, and now Commandos is working with CureROM
        hey man..could u help me plz...i think that i have the same problem you had...i got commandos S.F. but i cant manage to run the game...after doing all the profile on Curerom 1.3.1 i got the following message:
        what you did to get it running properly?
        you said that you reinstalled DT403, are u refering to Daemon tools 4.03HE...i have also got it....
        if you could help me...
        regards man!
