I'm new to daemon tools..soooo u get it! :P
I just recently installed daemon tools and downloaded a GTA:San andreas.iso by hoodlum.. which should work..
anyways i can mount the image.. and when i go to My Computer..
i can see CD Drive (E
but the picture just shows a cd.. not the gta icon or w/e.. and when i double click the icon it tells me "Windows cannot read from this disk. The disk might be corrupted, or it could be using a format that is not compatible with Windows." I did a search, and found several posts concerning this.. but cant find a solution or cant understand.
In my Device manager, when i click "DVD/CD-ROM drives" theres two things.
"GZ0955W ADJ597A SCSI CdRom Device"
and
"LITE-ON DVDRW SHW-160PS6"
Not sure what the first one is... hmm
Someone please tell me a solution or if u need more info just ask and i will try my best plzzz i really want to use this. Thanks-
but the picture just shows a cd.. not the gta icon or w/e.. and when i double click the icon it tells me "Windows cannot read from this disk. The disk might be corrupted, or it could be using a format that is not compatible with Windows." I did a search, and found several posts concerning this.. but cant find a solution or cant understand. In my Device manager, when i click "DVD/CD-ROM drives" theres two things.
and
