Need 4 speed most wanted - HEEEELP
  • Need 4 speed most wanted - HEEEELP
    Hi all, im new ^^
    I've a problem to mount the NFSMW image in the virtual device... after i try to mount it on the device and i go to look in and click on the speed.exe to launch setup this doesnt start but starts only a small dos windows that closes after about 2 milliseconds...
    How can i do to play nfsmw ???
    PS: i tryed same thing on alchol 120% but nothing...
    You shouldn't have a dos box when you wanna install the game. How did you make the image? What tools did you use?
    Carpe diem
      What does the DOS box tell you?
        I think your image is corrupted.
        Does any file have a content on the disc?
        Try to open the readme for example...
        I had once the same problem with an other image. how did you create the image?
        no way to hav phun wth sciendz
          Maybe you don't copy the cd
          You say a program that show you a DOS box, well that is a cr4ck from RIVERSTORM.
          1 - Must be copy "sd4hide" in the folder
          2- Mount the mini-image
          3- Put the link -Need for speed . . (Icluded in the crack) in your cr4ck
          4 - Run the link and enjoy
