hmm
  • hmm
    Originally Posted by esp2120
    Hello all. I am trying to play godfather using daemon 4.03 for image mounting. At first I got insert the correct dvd error. After I fixed that, I get a godfather.exe error. I have the exe set for windows 2000 . I am not new to this, so any answer can be straight forward. Thankyou for your time in this matter.
    John Dullebawn
    I had the same problem.
    I mounted the mdf file directly, because the mds file pointed to a different mdf file name, thats what created the problem.
    you have to change the mdf file's name to be exactly the file name of the mds file and mount the mds file, for example:
    godfather.mdf
    godfather.mds
    and thats it, it worked for me...
