The BSOD* is probably caused by Starforce drivers (prosync1.sys, sfhlp01.sys, prohlp02.sys, prodrv06.sys) - either un-install or update.
Starforce tools:
Update
Remove
If you still get BSOD after update, remove all Starforce drivers (you probably need to un-install the game(s) protected by Starforce) and install Daemon Tools.
Usually you can re-install the game(s) and won't encounter any problems anymore.
*BSOD = Blue Screen of Death
					Starforce tools:
Update
Remove
