You can usually fix this issue by disabling all virtual drives (i.e., set number of virtual drives to 0) and then re-enabling them. In general, this issue is caused by some application locking the drive and "forgetting" to unlock it.
This can also be the result of cdrom.inf / cdrom.pnf missing from C:\windows\inf.
To fix this you must first find these files:
[1]Search for cdrom.* on your windows cd.
[2]Ifyou find cdrom.inf or cdrom.pnf, copy these files to C:\windows\inf folder, and proceed to 'Reinstalling Driver' section below.
[3]If you find cdrom.in_/cdrom.pn_, open these files with winrar/winzip.
[4]Extract the single file to C:\windows\inf
How to reinstall driver:
[1]Start device manager; If you have win9x, right-click my computer, goto properties, then device manager; for winnt, run devmgmt.msc.
[2]Goto DVD/CDROM drives, and right-click the stealth drive, and goto properties.
[3]Look for reinstall driver button, and click it.
