- Start device manager (run devmgmt.msc [winnt] or goto control panel, system, device manager [win9x])
- Goto System Devices section
- Delete Plug and Play BIOS Extension
- MAKE SURE YOU DON'T DELETE ALCOHOL'S (drivers: axv???.sys; D-tools should be called st3???.sys or d34x???.sys)
- Goto the SCSI section
- Remove the d-tools controller (not Alcohol's [AXV???])
- Delete Daemon Tools driver files (file names mentioned above)
I uninstalled d-tools but the virtual cdrom is still there
Tags: None
