Page 2 of 2 FirstFirst 12
Showing results 11 to 12 of 12
Thread: unable to mount from command line
    Please update to latest Daemon Tools version, and check if mounts ok.
    29.07.2008
    4
    FIX PROBLEM
    I try all options, but the problem happend when the network drive is already connect and try mount an image from command line.
    The problem fix when i disconnect network drive and connect from .BAT too with net use driveletter: \\computer\shared /user:user /persistent:no
    If the .BAT run all process work fine, but if network drive already mounted and .BAT only use the -mount parameter for daemon dont work. Cant mount an image
    Thanks for your time and i hope this answer help another people.
Tags for this Thread
