Page 3 of 3 FirstFirst 123
Showing results 21 to 26 of 26
Thread: [Freeware] Program for textcapture
  1. #21
    sYk0's Avatar
    27.12.2005
    392
    another easy tool to use (and it's free)...
    hxxp://www.x-spy.net/
    Mail:
    curerom @ daemon-tools.cc
  2. #22
    26.06.2007
    115
    @sYk0: Which Windows version do you use?
    STRG+C doesn't do anything on XP Sp2.
    Meanwhile I do not search for this tool any
    longer.
  3. #23
    Default ctrl + c from a message box
    Quote Originally Posted by sYk0 View Post
    why don't you just try "Ctrl + C" works for most standard message boxes (i assume you want the text from the message box that is)...
    This is the trick i use too, I'm so glad someone told me about it a while ago.
  4. #24
    26.06.2007
    115
    And which OS do you use?
    I know that it works under
    Linux.
  5. #25
    Kinlaadare's Avatar
    24.05.2005
    697
    Does under vista 32bits and XP x64. Didn't test under my 32bits XP.
    Carpe diem
  6. #26
    26.06.2007
    115
    Code:
    About
    DAEMON Tools 4.10 (C) DT Soft Ltd.
    Homepage: http://www.daemon-tools.cc
    Email support: support@daemon-tools.cc
    SPTD 1.50 (C) Duplex Secure Ltd.
    OK
    Seems as if it also works in WinXP,
    but not for all windows.
    But as I said I stopped
    looking for it.
