I'm using Win XP pro
Securom 5.* protected games with Daemon Tool 3.47 :)
Automatically change registry permissions on boot
I can't get this to work either (Windows XP SP2).
I got the error "Conflict with disc emulator software detected" until I shut down InCD (random access driver that came with my Sony DVD drive).
Now I can see HL2 process in Task Manager but it doesn't do anything. I also can't end the process.
Can you make clear - do we need to change the permissions of all the keys in the original post, or just the first one:
HKEY_LOCAL_MACHINE\HARDWARE\Devicemap\SCSI\SCSI Port 2
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\d347prt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\P CI\d347prt
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E97B-E325-11CE-BFC1-08002BE10318}
Anyway, for those who do have it working, you can automatically change the registry permissions on boot - see here: http://support.microsoft.com/default...b;en-us;245031
I created a HL2RegIni.txt file with these contents:
\Registry\Machine\HARDWARE\DEVICEMAP\Scsi\Scsi Port 2 [8 17 19]
\Registry\Machine\SYSTEM\CurrentControlSet\Control \Class\{4D36E97B-E325-11CE-BFC1-08002BE10318} [8 17 19]
\Registry\Machine\SYSTEM\CurrentControlSet\Enum\PC I\d347prt [8 17 19]
\Registry\Machine\SYSTEM\CurrentControlSet\Service s\d347prt [8 17 19]
And a HL2RegIni.bat file in the same directory:
@echo off
regini HL2RegIni.txt
Then I put a shortcut to the bat file in my Startup folder, and that does the trick.
thanks for th einfo. i'll see if i can use your method to change the registry permissions on boot.
btw, for me i just need to change for
the rest of the keys no need to change. and i only use alcohol 1705. no daemon tools at all.
Hi,
so for all of u, who canґt start ur game because nothing happens if u start ur exe. First try to start ur game with the original dvd, if this doesnґt work itґs not the securom 5 problem but a HL2 Problem, so look at http://www.steampowered.com/forums/ for solutions!!
@Shellshock
U just need to change the first one for Administrator as i wrote on the second page! Just read my faq and it should work, but ur hl2 with original dvd should work before!!!
Originally Posted by beepoobeethanks for th einfo. i'll see if i can use your method to change the registry permissions on boot.
Originally Posted by DoubleJwith the original dvd i can start the game without any problems. but after making the registry changes und mounting the image nothing happens. the hl2.exe apperas in the taskman and after some seconds it disappaers. after unmounting the image and inserting the dvd in a physical drive everything works fine again!
My problem is now that my Windows 2000 Prof haven't the regini.exe and it isn't in the support tool kit on the cd too. Can someone please send me the regini.exe and explain to me how to get it working globally with windows?
Originally Posted by MosefThis happened to me too, but now it works. The problem is the Image.)
you could make the Image with a BlindWrite profile especially for Securom new 5. the Image done with this was better than the one i made with automatic.
I hope i can link it without being slapped...
unrar it in the BlindWrite5\profiles dir...
and when this don't work, look for a better b5t-file. I think i cant link this here or?
Originally Posted by MasterCAfter changing the registry I could no longer open the device manager. What can I do?
Good luck.
Meanwhile, has anyone who experienced nothing after the "preparing to play..." message had any luck getting further?
Follow these instruction and itґll work. Damn simple! But only in german. But the pictures explain enough I think. Another suggestion from me: Open device manager(Gerätemanager in german) double click your cd/dvd devices to see which bus number the daemon tool device has. Then change only the equivalent setting in your registration. It works fine!
