With a little help from Google I've translated the German instructions. The screenshots are still in German.
Half Life 2
To avoid having to have the Half Life 2 / Counterstrike: SOURCE DVD in the drive when playing, you can create an image of the DVD and use DAEMON Tools to create a virtual drive. But Valve and/or Sony suspected this would happen and have already inserted some months ago a Blacklist into the "SecuROM" version 5.x copy protection, which is used by Half Life 2.
To get round this, first create an image of the DVD. With the help of the attached BlindWrite5-Profile http://forum.copybase.ch/de/uploads/...fil_SrNew5.rar (save the file to the BlindWrite5\profiles directory; you need WinRAR 3.41 to unzip the file) and BlindWrite you can create a medium data image of the DVD (" image") using the "Read" menu (screenshot 1).
The DVD image has now been created in the Blindwrite B5T format and can with a few mouselicks in the DAEMON Tools Tray menu (screenshot 2) be mounted.
If you now to start Half Life 2 it will fail. This is because of the Blacklisting function previously mentioned. To get round this, go to the Start menu, click Run, and enter "regedit", and hit OK. Now navigate in the tree to the path HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP \Scsi Port N, where N depends on the number of attached drives and installed emulation software.
Find the Scsi Port N key for the DAEMON Tools, Alcohol120% or other emulation software that has the Half Life 2 image mounted. For DAEMON tools, expand the Scsi Port N keys and subkeys to find one called "Logical Unit Id 0". The DAEMON tools virtual drive has an Identifier of "Generic DVD-ROM" under this key.
Sony's SecuROM looks under the "administrator" group for the installed emulation software. We can prevent SecuROM by finding this by setting the Permissions on the appropriate key to deny read access. (screenshot 3). Right click the Scsi Port N key and select Permissions from the pop up menu. Select the Administrators group and for the Read permission tick Deny. Click OK. You will need to do this every time you boot your PC, as the change is not permanent.
You should now be able to play Half Life 2 without the DVD in the drive.
Screenshots (these are urls not img, and img doesn't seem to work):
[ 1 ] http://forum.copybase.ch/de/index.ph...pe=post&id=205
[ 2 ] http://forum.copybase.ch/de/index.ph...pe=post&id=203
[ 3 ] http://forum.copybase.ch/de/index.ph...pe=post&id=204
PS: Before you use the virtual drive for other progrems, you should change the Permissions back again in regedit, by untick the Deny box for the Read permission, and ticking the Allow box for Full control.
Half Life 2
