I have problems with this game.The way i used for POP T2T and Toca 3 ( nforce 4 MB + sata harddrives + disable pata controller , mount and play ) is not working anymore.The starforce version is 3.7.16.4. I noticed that the message displayed by starforce is always "Failed to identify the disc".This message is displayed even if the controller is not disabled.The previous starforce versions gave message "Insert disc in other drive" right after double clicking on the game .exe file in this case and the mounted image was not even checked.Now with this version it looks like the mounted image is always checked ( no matter if there is real drives connected to the system or not ).I am not sure what exactly is the reason for that but i have some ideas:
1. Wrong DPM info ( bad .mds fle ).Possible but not very likely.I used the same hardware ( NEC 3540 ) and software ( Latest alcohol ) and settings ( dpm high and low extraction speed ) that worked fine for POP T2T and TOCA 3.
2. Some new kind of blacklisting that prevents alcohol and daemon tools 4.0.3 ( i tried with both of them ) to emulate correctly the disc topology.
I can't test with unplugging of the optical drives now so if somebody can make this test please tell us if it is working.If anyone managed to make working backup of this game please tell me how you managed to do that.
