I don't have DVD's with one of the mediacodes but i read in forums that this trick does not always work.Sometimes it works and sometimes not.If you have the CD version you can try to use the special patch and burn the image to cd and this will work 100% but it will work only for the cd version.If you are interested PM me to tell you more about the patch.
Rise And Fall: CaW - Starforce 3.7
Yes there is the tool wich modifies the mdf/mds file for the cd's media.... The problem is nobody found it yet.
but for now it still the same burn the 1:1 copy and hope for the best.... and get DVDinfopro.
DAXON...D42.9
BenQ
Eron
Fujifilm
Medion
PHILIPS.041.9
BenQ
HP
LG
Maxell
Memorex
Philips
Sony
TDK
RICOHJPNW11.9 ( On DVDinfopro at least for me shows as RICOHJPNnW1 or RICOHJPN1W1 )
BestMedia Platinum
Fujifilm
Imation
Maxell
Memorex
Octron
Philips
Ricoh
Ridata
Sony
TDK
Traxdata
Quick Format the DVD-RW with dvdinfopro.
and burn the image with alcohol 120% on 4x without rmps.
Worked for me anyways.
buy DVD+RW from these brands and media code:
burn without RMPS and newest alchol. play.
maybe you need a IDE to USB cable, not all IDE work this way.
wait til a DT update will be released and u will hopefully be able to play it without burning it on specific DVDs.
@teobf: atm this is simply not possible. u will have to wait for a new DT version...
