yep, target is correct, of course. you need to set the working folder to point to your TQ folder, too.
Titan Quest
Well sadly i have to report that nothing seems to work for me...
i've trying allday with titan quest version 1.08 and 1.11... i tried allmost everything i've found in this thread..
i get either the "emulation software detected" either "cannot start the security module" msgs or if i use the curerom shortcut or the securerom loader NOT in the game directory i get simply an error log from titan quest.exe crash...
i start to believe that the problem is that i am using windows 2000 and not XP.
jett titan quest!
@ Congoman jepp its worke Fine
first. Greets from germany
Download curerom_loader
make a linkage from Cureromloader at the desktop
then go to the desktop and write in the linkage
D:\CureROMLoader.exe -a "D:\Game\TitanQuest\Titan Quest.exe" -c1
Mount the titan quest and start with the linkage
...works for me fine
...see u ,
masterthey can steal our \"source code\",
...but never our \"hearts & Soul\"
