I'm surprised there's not a thread about this game already. I am trying to play the game without the crack, since it apparently can cause crashes.
I'm playing off a full .mdf/.mds image and a mini-image, and I get identical results when loading either. The game runs with SecuROM 7x, so I have been mounting with the NEWEST DT (4.03 with the new drivers) and using SecuROM Loader 1.2. When I use just that, it says "Conflict With Burner Emulations Software Detected." I get the same message when I use CureROM Lite BETA 3 in conjunction. When I use either SD4Hide or SR7.Stop 1.0, (SR7.Stop says "Nothing to Hide" when I hit "hide") I get the error "A Required Security Module Could Not Be Activated."
I don't have any other emulation software installed, and I'm running WinXP Pro with all of the newest updates (Silly WGA).
I am successfully running Hitman Blood Money from an MDF image, using ONLY the ASR.EXE.
Can anyone offer me advice? The full image is burned with RMPS emulation. Should I have that emulation enabled in DT? (It doesn't seem to make a difference for me) Is there any anti-blacklisting software or loaders I should use instead? I hear alot about pr0t.stop, but that and sr7.stop are the same thing, right?
Sorry for the long post and thanks for any advice you might share.
