Now that the old Mech Commander games are free, anybody use daemon tools to run it? I'm currently getting a message to insert the drive when I tried to use the downloadable ISO.
Issues with MechCommander 2
 Yes, I downloaded the iso from http://mechcommander.org/getmc2.html , mounted the image using deamon tools, and installed from there. I then tried to run the game with no luck. I tried the different emulation options, but got the same result.
