I am trying to play Doom 3 but it won,t allow me too, what have I done wrong. Farcry worked for me when I did it the same exact way.
cd/dvd emu software detected please disable and restart game
Scanning -> E:\Program Files\Games\Doom\Doom 3 Demo\Doom3.exe
File Type : Exe, Size : 6659308 (0659CECh) Bytes
-> File has 1199340 (0124CECh) bytes of appended data starting at offset 0535000h
[!] Safedisc 3.20.022 detected !
- Scan Took : 2.735 Seconds
Scanning -> Y:\Setup\Data\Doom3.exe
- Scan Took : 4.938 Seconds
I used alcohol52% to make the mdf and mds files, I also did the same thing with farcry but I had to use a copy of the game disk to run off the virtual drive, I had to use a combo of the 2.
