Problem starting game with copied cd or virtual drive
  • Problem starting game with copied cd or virtual drive
    I followed the instructions in the daemon tools help under usage to the letter, I used blindwrite to copy the cdrom and alcohol52% to make the .mds files, I mounted them but all I get is an error, Doom 3 has encountered an error and must close. However I used to get an alert that said (Doom has detected cd/dvd emulation software, you must disable and restart doom). I uninstalled the game and reinstalled according to the instructions in Daemon Tools Help under usage. I made sure emulation safedisk was on, reinstalled the game and made a copy of the cd, (with blindwrite), then created my mounting files all without removing the original cdrom. But I still get encountered error. Can anyone tell me whatsup.
    Disable safedisc emulation and it should work (no doom3.exe has encountered an error ... anymore).
      It still doesn't work, I get the same results.
        Fixed it
        As it turns out, activision had a patch to correct cd/dvd emulation problems.
          Latest patch for Doom removes copy protection.
