I had Age of Empires II: Conquerors expansion mounted on a virtual drive with Daemon Tools. It worked fine until I uninstalled Norton and replaced it with Zone Alarm. Now when I try to run the game I get this same error. I get the error wether I try the original CD or the mounted image. I uninstalled Age of Empires II and the expansion and D-Tools. Reinstilled the game and I get the same error on the expansion of the game only. I can play the original and all other cd's/software work fine in that optical drive.
XP Pro is fully updated as is Zone Alarm and inside ZA all permissions were reset for both after uninstalls.
Your help is appreciated
-Damage
-Damage
