Command & Conquer 3 - Wrong Disc Inserted Error
  • Command & Conquer 3 - Wrong Disc Inserted Error
    I made a backup of the game using alcohol 120% using high dpm measurement. It created the mds and mdf files and I mounted the mds on the latest version of daemon tools. But when I click play, it gives me an error a few seconds later saying Wrong Disc Inserted. Please insert the correct cd/dvd. Anyone know what's wrong? I updated it so could that be why?
    Use YASU to cloak the drives from SecuROM.
      The latest patch at this time for C&C 3 is 1.2 and Yasu 1.1 build 7035 doesn't work.
      The original install from the DVD worked with Yasu 1.07 so we have to play with the original while we wait for the new Yasu I guess.
        Yasu 1.1 build 7035 does work for C&C 3 1.2 Patch (!] SecuROM Detected - Version 07.32.0009).
        Maybe you could post your error.
        BTW latest patch is 1.3, atm i download it
          Hi,
          I use the latest Version 1.2 for C&C 3 and I use Yasu 1.1 build 7035 and all works fine.
          If I mount the Image before I have started Yasu I get an error message, but if I start Yasu before I mount the Image it works.
            Patch 1.3 is still in developement !
            There isnt a online or standalone version available !
            ftp://ftp.ea.com/pub/eapacific/cnc3/
            sysProfile (Click me)
              That has to be a record. 3 patches in the first week of release? Besides MMO's, I can't think of any other game that's done that. Sheesh.
                2 words... Electronic Art
                  You are right, maybe I had an old version of Yasu loaded when I tried build 7035. I don't reboot very often but I just did now and it's working.
                    1.) Standalone Patch 1.3 is out now
                    2.) Its good that EA publish the patches so fast, so everybody with probs can play now. Okay there still some that have probs with the game.
                    3.) C&C3 runs flawless on my rig, dont know why they have such probs
                    Besides this, the game is awesome.
                    • #11
                      FULL ACK.
                      MfG, Benni
                      Mail: benni@copybase.org
                      • #12
                        I agree, Mystique. Right now I'm playing the GDI campaign on my main PC, and at work on lunch I'm playing the NOD campaign.
                        • #13
                          Keep in mind that you need both campaigns completed to play the 3rd campaign of Scrin!
                          • #14
                            yep, only thing that sucks is you cant replay previous missions to gain all the intelligence data, and the scrin campaign is pretty short..
                            • #15
                              Ok, now I'm frustrated. I'm on the Cairo GDI mission, and I hate it. I despise "defend" maps, especially when I can't build new structures/defenses, and I have to defend two objectives at the same time.
