Command & Conquer 3 - Wrong Disc Inserted Error
  • #46
    Originally Posted by Mystique View Post
    Maybe the *.mds file is incorrect.
    Try this one from my C&C3 and use latest DT with YASU !
    I have downloaded the file and loaded to DT it says the file is not accessible. Any ideas?
    • #47
      You need a complete image (.mds and .mdf) and swap the downloaded one with your original. Both files need the exact same name before the dot...
      • #48
        BackUP
        Normally I create a backup disk of my games so that I can put them away in a safe place and not get damaged, but it didn't work for C&C3. I normally just use Nero and it has worked every time so far except for C&C3. I used a Dual Layer disk and a my Rom can write and read them so what is going wrong? Do I need to use a different piece of software?
        Please Help
        • #49
          Nero can't backup protected disks. Use Daemon Tools Pro/Alcohol 52/120% to create a working image.
