since the update to version 1.1 it seems it makes more trouble running it from image than before. it sometimes takes several tries to run.
but in my case it allways works if i remount the image (unmount and mount again) than start it from autostart menu. it does not work by only doubleclicking the drive to get to autostart menu.
after remounting the image it allways works at first try.
