I have a .mds / mdf file created from the original CNC3 tiberium edition DVD using alcohol with all the specified options
I have the drive letter I: for the emulation
Here are the steps I usually do
1. Disable the DVD ROM
2. Start Daemon tools and Emulation --> all options ON
3. Mount the image CNC3.mds
4. Start NERO drive speed and set the speed of the drive I: to 1X
5. Start YASU.exe Y.A.S.U v1.4.7080
Then I click on the "Play Command & Conquer 3 Tiberium Wars" desktop icon.
It works but only sometimes
One day it will work and the next day when I follow the same steps as above I get the error " Please insert the original disc instead of a backup (1000)"
On an average out of 10 times.. 3 times Im able to play the game but 7 times I get the same error " Please insert the original disc instead of a backup (1000)"
Any help will be deeply appreciated
Some more details
1) My computer has AMD athlon
2) I installed the 1.06 patch of CNC3
3) I have AVG anti virus and I disable it always when I play CNC3
again the most baffling thing is it works sometimes and it does not work sometimes
Some more details
