Hello everyone.
I have been using DT for some time, mostly for this and that, all successfully. It still works like a charm for Diablo2. Thank you for that!
However, I have now perused quite a number of threads and am stuck. I even downloaded the upgraded version of DT-Light, which comes with that incredibly pesky AdVantage program, but still no luck.
My problems are with 1. SW:KotOE and 2. Civ4
1. I recently received KotOE, and patched it to the latest patch. Runs fine. I made a .bt6 from BlindWrite 2 days ago -- my Alcohol120% license apparently ran out, and I dont quite have the cash to purchase the full version --. The image mounts without a problem, but when I try to play from it, I receive the message "Please insert original disk, not a backup copy. See Securom.com for more details". I searched the forums and saw that the newest version of DT should do the trick, and am surprised that this is not the case. Am I simply out of luck?
2. Similar experience with Civ4, except that it "does not find the drive". To be sure, I made blindwrite copies from both disc 1 and disc 2 and mounted both, because I read that there was some confusion as to which disc was actually the playdisc. Either way, I have been unsuccessful in being able to play the game.
I also have all emulation options clicked on. Still works fine for Diab2, so this is obviously enough for that version of SecuRom, but not enough, strangely, for KotOE.
Although I can no longer use Alcohol 120% (deinstalling and re-installing obviously doesnt help, since it remembers that I tested it earlier), I was sure that BlindWrite would, since this is also recommended. Is there any thing else I should know about?
thank you very much in advance for your help
-o
-o
