2 Problems - Civ4 and SW:KotOE
    @onomastikon
    Please check the first link provided by bismax to create image with correct settings
    Originally Posted by onomastikon View Post
    The .mds is only 1kb, and that is the one that DT wants to have mounted (I cannot even select the .mdf) -- is this correct?
    Yes, but the mds size has to be around 26 KB - provided image was created correctly.
    I also have compatibility mode for WinNT selected, as Terramax suggested, but no luck.
    This may only be needed if a "correct" image still doesn't work.
      Thank you, will do!
      (Does everyone elses posts have to wait till a mod ok's them? I've never seen this anywhere else!)
        yes.. unless you are (1) a customer, or (2) have 20 or more posts...
          If your mds file size will als be around 1 kB, your burner has not been supported yet.
          If you've got ICQ or MSN, you can also contact me via these.
          Just write me a PM.
          Schreibt mir eine PN!
            It seems I have done everything correctly, and I still cannot get KOTOR to work. I am on a Vista machine now, I have a good image (I think, since I followed instructions) of 27kb, and this seems to be working with my other games. I still cannot get KOTOR to play, however, it says there is a conflict with Securrom. Can I send anyone my image so that they can have a look at it and tell me what is wrong? Thank you!!!
              I havent received any replies for whatever reasons (have I offended?), but I will risk posting some odd news:
              On my machine, I cannot actually play KotOR with the original disk in! Apparently, the only time I was able to play it was directly after installing it; now, when I try to launch the game, I get a "securerom" error.
              After consulting the website of the evil securerom people, I have the original game CD in, turned demounted all images, turned off all emulations options and exited daemon tools lite -- and the game still wont launch with the original CD in.
              HELP!! What's going on? Have I destroyed something? Anyone?
              THANK YOU very much in advance.
                Kotor 1 and Kotor 2 and Civ 4 works fine for me but I am using dt pro advanced.
                  what error message do you get with securom? usually some number is in the hyperlink in the messagebox... please paste it
                    @onomastikon
                    Try to execute the game in different compatibility modes.
                    Which OS are you on ?
                      Thank you very much.
                      This is Vista Home Premium OEM.
                      The error message was: Conflict with Disc Emulator Software detected. See www.securom&emulation for more details.
                      That site indicates that I must shut down all emulation software. I deactivated daemon tools lite (turned all options off, exited the program) but I still cant get it to work.
                      I hope I havent broken something. Thank zou so verz much for zour help.
                        @onomastikon
                        Rightclick the SW KOTOR shortcut on your desktop -> Run as Administrator
                        If that doesn't work rightclick the SW KOTOR shortcut on your desktop -> Properties -> Compatibility
                        There tick 'Run this program in compatibility mode for:' and select Windows NT 4.0 (Service Pack 5) in the dropdown menu.
                        EDIT: Would you please upload your 27 kb mds file ? ...Deja vu :wink:
                          THank you.
                          I still see no way to attach files to my posts here. Do I need special privledges for that?
                            yup, think you need 20 posts or higher.. only 9 to go
                              @onomastikon
                              Just upload it to some one click hoster like e.g. sendspace.com
                              Have you in the meantime tried to run the game as Administrator or in the mentioned compatibility mode ?
