Hi guys im new to this forum so any help or comment is greatly appretiated.
I make the MDS and MDF image file using Alcohol 120%. After that i uses Daemon Tools Lite ver. 4.12.0220 to mount the image.Lastly i started the yasu lastest version.During the process of making the image file, i keep getting one error "Cannot get the right DPM info from the dise with current devices"though the image is still able to be made.The DATATYPES set is securerom for this process.
When i run the game, it prompted with with this quote " Please inserted the original dise instead of the the back ups copy "
I also did tried to use Daemon Tools Pro (basic) and Daemond Tools Lite Editon to mount the file to one of the virtual drivers but the same problem still continue to exists.
Right now,im using a burned dise image by Alcohol 120% and it works though the loading to the game takes up longer then the orginals ones but other then tat is doing well.However i realli hope can played it without the dise.So anyone can post me some helps or solution. thanks for the help in advance
My System's OS
Window XP Home Edition
My System's OS
