OK, I bought C&C 3 Tiberium wars as well as the expansion pack, Kanes Wrath. installed both, made my image of Kanes Wrath with Alcohol 120%. Here's where the trouble began, initially it didn't work because I hadn't made the image at a 1:1(?) speed. So i remade the image again, as slowly as i could. Mounted it on DTools, loaded up YASU and Everything worked fine.
However: EA, recently patched Kane's Wrath and ever since then I have been getting the following error whenever I try to run the game with the image. "A required security module cannot be activated.
This program cannot be executed (5023)."
I'm using the latest version of Dtools and YASU, I have securom emulation enabled and my drives are cloaked. Am I going to need to burn another image or is there something else I can do to fix the problem?
