Hi
I've owned Tell me more Performance 10 with activation key, and i am tiring of carrying and using DVD all the time. I would like to avoid it.
I've tried to make an image of this DVD under Alcohol 120 but i have received reading errors. I can't solve it on myself.
Alcohol says it is StarForce Keyless(000000040) protection , which version? i don't know how to check.
i have used default options:
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
SCSI Pass Through Direct (SPTD) layer version: 1.62
CPU Priority Level: High
Memory Buffer Size (MB): 256
Examine the accuracy of data read from physical device: Yes
Enable Enhanced Weak Sector Scanner during dumping: Yes
Overburn disc(s): No
Turn off "Auto-Select best write speed" function if possible: No
Fill memory buffer before recording discs: Yes
Book Type DVD+R/DVD+RW disc as DVD-ROM while burning: No
Ignore Media Type: No
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Thanks for help in advance .
