I think they will fix it as soon as possible...
SACRED newest patch1.55beta9 prevents emulation
i used to play sacred with an rmps copy and, since 1.6 in conjunction with daemonscript, as described in some other thread.
today i read a lot about blacklists of daemonscript. though i cannot conform this, i wrote a small script for the windows scriptting host. perhaps you'll need to adjust the folder to correctly locate the d-tools.
place in in your game folder and execute it. needs windows scripting host to run. wonder if they'll blacklist that, too!
save the following as sacred.js in your game folder
//SCRIPT
RunSacred();
function RunSacred()
var WSHShell = WScript.CreateObject("WScript.Shell");
var i;
WSHShell.Run("c:\\Programme\\D-Tools\\daemon.exe -rmps on",1,1)
WSHShell.Run("sacred.exe",1,0)
for (i=0; i<50; i++)
WScript.Sleep(500)
WSHShell.Run("c:\\Programme\\D-Tools\\daemon.exe -rmps on")
//END SCRIPT
works fine!Mounty Bob strikes back
Originally Posted by CongoMani used to play sacred with an rmps copy and, since 1.6 in conjunction with daemonscript, as described in some other thread.
//SCRIPT
RunSacred();
var i;
WScript.Sleep(500)
//END SCRIPT
works fine!
Windows Script Host
Script: E:\Program Files\Ascaron Entertainment\Sacred\sacred.js
Line: 8
Char: 1
Error: The system cannot find the file specified
Code: 80070002
Source (null)
I made sure that it was pointed to Daemon tools, and I put the .js file in the folder where sacred.exe is, but other than that, I'm not sure what I could have done wrong. Any ideas?
the .js script works perfectly for me. maybe (i dunno) itґs because of the blanks in the path. i do not have blanks in either path (daemon and sacred). havenґt verified this ґcos iґm at work now, but ...
well, you might want to give it a try.Mounty Bob strikes back
hey ho!
i have forgotten to tell you to to install the scripting host. download http://www.microsoft.com/downloads/d...7-3cffcb0c2524
script will work then!Mounty Bob strikes back
yes, thatґs what i thought, too. but when i tried to reproduce the reported errors on my office computer i was successful (in creating the errors, donґt misunderstand me). so i just gave it a try, installed the wsh and ka-boom, the script worked.Mounty Bob strikes back
The reason its not working is because Xp has a bug and I believe its going to be updated in service pack 2. It can't handle long filenames. Change the script to this:
Yours:
Line: 8
Char: 1
Code: 80070002
Source (null)
Correct:
Script: E:\Progra~1\Ascaro~1\Sacred\sacred.js
Change all types to the old dos style filenames.
Btw, this will NOT work with the US copy or ENU copy. D-tools is blacklisted.
Originally Posted by DodgerI tried your script but got the following error message:
Windows Script Host
Line: 8
Char: 1
Code: 80070002
Source (null)
I made sure that it was pointed to Daemon tools, and I put the .js file in the folder where sacred.exe is, but other than that, I'm not sure what I could have done wrong. Any ideas?Lumpi
Originally Posted by Twisted EndZThe reason its not working is because Xp has a bug and I believe its going to be updated in service pack 2. It can't handle long filenames. Change the script to this:
Yours:
Line: 8
Char: 1
Code: 80070002
Source (null)
Correct:
Btw, this will NOT work with the US copy or ENU copy. D-tools is blacklisted.Unfortunately, I still get the cd verification error.
Ah well, to be honest, unless they patch the game enough to actually make it worth playing, I doubt I'll wear out my original disk. :mrgreen:
