There is another way to play Sacred with an Image:
I used the german Sacred version and it only worked with Patch 1.5 so far, with higher Patches I get a BSOD (IRQ_NOT_LESS_OR_EQUAL error :shock
But feel free to try it.
1. Install Sacred, download Patch 1.5 and install it.
2. Mount the Image with D-Tools, RMPS on
3. Now open up Windows Explorer and go go to your Sacred DIR.
4.Run updcheck.exe and right after that, without (too much) delay, the sacred.exe
5. Just sit there and wait.
Somehow, the running updcheck.exe prevents sacred from running the cd check correctly, so that ur game will start.
So everytime you want to play sacred, repeat step nr.4, and here we go *g*
But feel free to try it.1. Install Sacred, download Patch 1.5 and install it.
