Trying to emulate Half-Life 2 & no luck
  • Trying to emulate Half-Life 2 & no luck
    ok im trying to emulate a retail copy of half life 2 i bought & u may ask why dont i run it straight off my cd-rom reason being i dont is because my cd rom seems to be tempormental with securom protected games (dont know why,works fine with other protections).im useing blind write with the auto settings but when i mount the image on daemon it comes up with a message saying conflict with emulator & to go to the securom website for more info.so if somone can tell me what im doing wrong or if theres some settings i need to change ied be very greatfull for any help..
    thnks in advance
    There're threads about HL2 and SecuROM in our copy protections forum - check 'em out.
      I got Half-Life 2 to work 8)
      1..install DAEMON Tools and BlindWrite 5
      2..make iso with BlindWrite 5
      3..Emulator with DAEMON Tools
      4..and run regedit.exe and change the driver to atapi
      [HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\Scsi\Scsi Port 1]
      "Driver"="atapi"
      [HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\Scsi\Scsi Port 2]
      "Driver"="atapi"
      [HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\Scsi\Scsi Port 3]
      "Driver"="atapi"
      and then starte i the game
      i made a regedit file i can run after windows hav starte
        "Driver"="atapi"
        "Driver"="atapi"
        "Driver"="atapi"
        Thx Man .... it worked fine ...But my Iso is made whith UltraIso..
        so that one works to ...
        Thx again..
          I heard valve made the retail version behave like the steam version now so you dont even need the CD.
