could somebody clarify what the usb method is or give a direct link to where it is explained?
Worms 4 : Mayhem
USB method: disable all your optical IDE drives, buy an IDE->USB adapter and put your IDE drive in there, connecting it to your computer via USB.
If IDE drives are present, you cannot play from any non-IDE drives. If none are present, it works. But supposedly, the newest StarForce version has overcome this trick too.
You can also just disable your optical IDE drives by switching off your computer, unplugging them (either power or IDE cables) and switching it on again. Then you have no IDE drives either so you can play from Daemon Tools.
By the way, you could easily have found this information by using the
Search button! :roll:
Well, no. I have tried unplugging the IDE drives and that didn't work. I could not start the game with D-tools. I got the following message: "Disc read error when checking disc. Make sure a licensed disc is in the drive, the disc is not damaged and the valid Disc Key is entered."Then you have no IDE drives either so you can play from Daemon Tools.
I had entered the correct cd key but i guess this has to do with the fact that d-tools does not support SF 3 emulation yet. So, i think we are just gonna have to wait for the new installment of d-tools.
However, if somebody else managed to actually start it using d-tools or any other app, plz post.
I tried ths too, no (correct) DPM mesure.Quality 0% BWAedit :? I think my reader PHILIPS CDD5301 is a shit :cry:Originally Posted by masteryoda34You cannot make a DPM of a StarForce disc with the StarForce drivers installed because they disrupt the process. (Usually at 33%) If you want to make a DPM of a StarForce disc then remove the drivers before making the image. As soon as you try to start a StarForce game again, it will automatically reinstall the StarForce drivers and prompt you to restart your computer.
To find if the StarForce drivers are installed on your computer follow these steps.
1. Right click on my computer and select properties
2. Go to the hardware tab and click on device manager
3. In device manager, go to View and click on "Show hidden devices"
4. Click on the expand icon (+) next to the "Non-Plug and Play Drivers"
5. Look for 3 entries labeled, StarForce Protection Environment Driver, StarForce Protection Helper Driver, and StarForce Protection Synchronization Driver.
If these are present then you have StarForce drivers installed on your system.
No. By the way Starforce prevent the use of simple copies... You need emulation and other tricks for a starforce protected game to run from a copy.Originally Posted by Action GrantTo make a backup of worms 4 cant you just burn it onto a DVD and then play it off that? (yes I know this is an emulation forum but im just curious)Carpe diem
To not only remove but also check for St0rkForce driver presence i'd suggest using their Removal Tool, if it wants to reboot they were there.. :P i got two of their birds which will NOT show up in device manager on at least one system for what reason ever._____________________________________
USB method
TheMerovingian, the USB method DOES work with DAEMON Tools v3.47Originally Posted by TheMerovingianI had entered the correct cd key but i guess this has to do with the fact that d-tools does not support SF 3 emulation yet.the modern world:
