Has anybody had any success trying to make a backup of Rollercoaster Tycoon Wild? It uses Securom 7 and is giving me lots of trouble.
I used Alcohol to create the image and played it safe
I enabled:
Skip Reading Errors
I selected Securom *NEW (4.x/5.x) profile
Read Sub Channel Data
Data Position Measurement High 1x speed
RMPS
Burnt at 8x
Ok well I run and it says "Security Module not Found"
I figured D-Tools was being blacklisted. So i get "SR7 Stop" run it and now it gives me a no disk found error.
I also tried Virtual CD Hide and still no luck.
P.S I also tried mounting with Alcohol with no luck.
I enabled:
Skip Reading Errors
RMPS
Burnt at 8x
