I've been searching alot lately for a way to run X3 with a mounted image, and although there are many guides out there, i couldn't seem to get them to work, after one post buried somewhere in the fourm and a few trials i finally got it to work. Now DT4 is supposed to support it without somthing so drastic but heres my hopefully simply explained version.
Programs needed:
SF Cure - it comes in a SFcure01.zip and contains 3 batch files, !start.bat, !Stop.bat and !Install.bat. Along with outher files...
Starforce Nightmare - It comes in a sfn.rar and contains 3 readme's and a SFNightmare.exe.
Alcohol 120% 1.9.5 (Build 3105) - Image Making software, located Here!
Daemon Tools 3.47 - I dont need to tell you about these i hope
I dont have all the links of the top of my head so if anyone has the links i missed please post it. After you have these programs move on to the imaging process.
Creating the Image file
After you have that you need to make the image.
1. Install and Start Alcohol 120%
2. Select "Image Making wizard" from the graphic menu on the left.
3. Insert the DVD and select the drive the DVD is in as the "CD/DVD Device"
4. Read Speed can be left at whatever is the fastest! If the image doesn't work you could try lowering it, but for now go full speed.
5. If your using a FAT32 drive seperate the image at 4gb, if your NTFS you can use Never seperate (Dont know what you have? Then right click on your drive in my computer and select properties. it will be under file system)
6. Tick the "Data position Measurment" box and set the precision to "HIGH"
7. Click "Next"
8. Name the image. and set the image type to "mds" (I didn't get an alternative anyway...)
9. Click Start
10. It will then ask you for the Data Position Measurment (DPM) Measuring Speed. Choose "1x" (you can try faster I just cant guarentee it'll work!)
11. Alcohol will then make your nice 4.36 gig Image.
Mounting the Image:
The fun Bit and bit i had trouble with...
Mounting the Image Step by step.
Firstly If you use Alcohol regularly, remove any alcohol virtual drives you might have.
1. Install daemon Tools
2. Shutdown your computer
3. Remove the power cord from any Physical DVD or CD drives you have.
4. Start up the computer again.
(Not sure if this will make a difference but i disabled my cd drives in my Bios by changing it from Auto to none! cant guide you through this as all Bios's are different but you should be able to disable them and leave them off, Windows should pick them up as a PNP device and have them available when you power them back up again)
5. Start "daemon.exe" if it doesn't autostart
6. Right Click on the D-Tools icon in the Task bar and select "Emulation -> RMPS"
7. Right Click on the D-Tools icon in the Task bar and select "Virtual Cd/Dvd Rom -> Set Number of Devices... -> 1 Drive"
8. Right Click on the D-Tools icon in the Task bar and select "Virtual Cd/Dvd Rom -> Device 0 -> Mount Image"
9. Browse to the location of the image and select open to mount it.
10. Right Click on the D-Tools icon in the Task bar and select "exit"
11. When prompted to leave emulation options enabled click "yes"
Getting Around Starforce:
1. Extract SfCure01.zip to a folder on your HD
2. Browse to the folder and run "!Setup.bat"
3. Then Run "!Start.bat"
4. Extract Sfn.rar to a folder on your HD
5. Browse to the folder and run SFnightmare.exe
6. Select "Disable Node" and wait until "processing..." on the Title bar changes back to "Starforce Nightmare"
7. Select "Disable CD" and again wait until "processing..." changes back to "Starforce nightmare" on the titlebar
8. Finally Click "Disable Node" Again and close SFnightmare.exe when "Processing..." canges back to "Starforce Nightmare".
9. Run the game and it should detect the CD as the original.
This was done with Windows XP Sp2
Hope this helps!
Programs needed:
7. Click "Next"
9. Click Start
Mounting the Image:
Hope this helps!
