Anyone else experiencing reboots during the game copy protection check right when you start the game? It happens to me randomly and I cannot figure out what is causing it. I did read other peoples issues with reboots with SF checks though.
X3 Reunion - Using a mounted image
NO WAY!! IT WORKS! I"ve been trying for a month reading on various sites how to bypass Gayforce and now it works!Originally Posted by evolart@hotmail.comI got X3 reunion working great using DT4 and this method: http://www.daemon-tools.cc/dtcc/show...ht=right+click
This requires a SATA HD to work properly. I setup DT4 with all copy protections and then disabled all PATA devices via Device Manager. Then I loaded the image into DT4, installed, and played with absolutely no issues.
1. Disable PATA in device manager
2. mount on DT4 w/ no emulations
3. play!!!
If thats the only thing you see then you have your harddrive and your dvd-drive are using one parallel cable. Disabling that would crash your computer (obviously because they're on the same cable). You need to buy a SATA (serial ata) harddrive for the trick to work. So in your device manager, you would see:Originally Posted by balancei have a nforce 4 mobo
and under ide ata/atapi controllor
i just have "nvidia nforce4 parallel ata controllor"
do i just disable that?
thank you
-nvidia nforce4 parallel ata controllor
-nvidia nforce4 Serial ata controllor
And you would just simple disable the PATA one...
I tried Splinter Cell - Chaos Theory which is Gayforce as well and it works too.
i have sata hdd =) 2 raid 0 and 1 just normal. i only see "nvidia nforce4 Serial ata controllor" in scsi and raid controllor and in there i have the following:Originally Posted by DJSLYIf thats the only thing you see then you have your harddrive and your dvd-drive are using one parallel cable. Disabling that would crash your computer (obviously because they're on the same cable). You need to buy a SATA (serial ata) harddrive for the trick to work. So in your device manager, you would see:
->D37PRT SCSI Controller (daemontool 3.47 i think, didnt want to update cuz 3.47 runs fine
->Nvidia nforce(tm) raid class controller
->nvidia nforce serial ata raid controller
X3 on a laptop?
It seems from what i have read you need to remove the power and IDE from optical drives to get this to work with emulation but i cannot do this on a laptop, tools like SFnightmare seem to do nothing, is there anything i can do? any sugestions are apriciated many thanks in advance.
Yes i realise this, and as mentioned in my post i've made images of GT Legends and Worms Mayhem. Both of these are starforce. Got hold of a new DVD drive today and it has created the image with no problems getting the DPM, now i've just got to try to run it.
I doubt Starforce is gunna be evaporating any time soon. I mean think about it, any game that forces you to unplug your drives so you can play a copied version must have really good copy protection right? If we gamers were making the games, we'd probably use it too so we could get $$$. It's all about the green.
And on that note, I need to go plug my cd drives back in; I wanna play ut2004 but I gotta install it first :/
I was hoping for companies who use it to go out of business - but the more popular Starforce gets, the more people are going to hack at it.
Also, I thought that was interesting, if you hold shift down when you start the game you get a box where you can enter a keycode - that will bypass security and start the game. You get such a code from the people at Starforce if they believe you are worthy - and it only works for your machine.
Amazing though that nobody has made a generator for that - guess you are right, it is a tough program
