just to let every 1 know that i have gotten Trackmania sunrise to work. but i had to disable my IDE cd drive. But the copy i have is an exact copy a true 1:1.
Trackmania Sunrise
Yup, Trackmania's copy protection - StarForce 3.4 - refuses to run from a SCSI drive as soon as an ATAPI drives (= optical IDE drive) is found. You can use StarForce Nightmare however instead of unplugging your drives: Click "Disable CD" to hide your drives. Then you can play TM:S as well. To enable, just press - you guessed it
- "Enable CD".
did u enable ALL EMULATION OPTIONS before mounting the image ? if u dint, do so....
for some reasons,it doesnt work without that.ive been playin my all time fav game since yest, trackmania sunrise.........and guess wat, also installed the EXTREME expansion pack.......its all crazy mayhem n madness....nadeo released it yesterday....400mb approx.....
hope that worked ........njoy
:p
MM, not here baby...Originally Posted by NetSoerferYup, Trackmania's copy protection - StarForce 3.4 - refuses to run from a SCSI drive as soon as an ATAPI drives (= optical IDE drive) is found. You can use StarForce Nightmare however instead of unplugging your drives: Click "Disable CD" to hide your drives. Then you can play TM:S as well. To enable, just press - you guessed it
- "Enable CD".
Disable CDRom... still not working
Extreme expansion wont work
The expansion dosnt work..i never could get this game to run...but after d/l daemon tools 4 and using sfnightmare it would run...but then i installed the expansion and all it will do now is say insert trackmania disk into another drive....there is no other drives and i even turned off the ide controllers in the bios..any ideas?
Trackmania Sunrise is protected with StarForce 3.4 which works if you disable your drives with SFN (I did that yesterday). If it doesn't work it's probably due to a bad image.
However, if you download and install the TM:S eXtreme addon the copy protection will be updated to SF 3.6 which recognizes SFN-disabled optical drives so you'll need to unplug your drives. I haven't found a way around this so far, sorry."I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
Funny...I used nightmare on one machine with a DVD burner left plugged in and it ran great....on another almost identical machine with a CD Burner nightmare would not hide the drive and I was forced to unplug.Originally Posted by coolbird22guys......y dnt u put this in ur minds.......
U HAVE TO UNPLUG THE IDE CD\DVD DRIVES and NOT DISABLE THEM USING NIGHTMARE.
STARFORCE STILL DETECTS THEM AND BLACKLISTS DAEMON TOOLS..
It doesn't blacklists Daemon Tools v4, starforce blacklists SCSI drives.Originally Posted by coolbird22guys......y dnt u put this in ur minds.......
He wrote that starforce detects them not blacklists them.Originally Posted by coolbird22hey thakap, that is wat i meant...........starforce blacklists them = SCSI drives ......duhh
And he wrote that starforce blacklists Daemon Tools, then I just pointed out that it doesn't blacklists v4.Last edited by Methadon; 20.11.2005, 17:13.
