Originally Posted by lis8910
v3.47 vs 4.00
Well, Need for speed : Most Wanted works fine with DT4 - wich is a surprise (no sarcasm...honestly
) ... But i heard that a few needed to run sd4hide.
Was mounted with the Alcohol 120% images (made with the newest version of AC120% ofcourse...)
Shut down your computer, open the case and look at the back side of your CD/DVD drives. There you'll have two cables: A red-black-black-yellow one which is the power cable and a much broader cable which is the IDE (data) cable. You need to unplug one of them (try the power cable first as it is easier to remove, if that does not work, unplug the IDE cable), that way your computer does not find the drives anymore."I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
I know it is always said that only general SCSI blacklists can overcome DT4, but even with my CD drive connected to a RAID controler (so windows sees it as a SCSI device) or my Physical drive disconnected entirely then SecuRom 7 still says 'disk emulator software detected', wheras the disk runs fine in my physical drive (which to windows is SCSI)
this leads me to think the blacklist is NOT just a catch all SCSI blacklist.... but thats just me.
Games run fine with the Anti-Securom Loader, but we were sold on DT4 ont he basis that it would remove the need for all these extra utilities
