Powered by vBulletin Version 3.5.4
subchanell and starforce
Re: reading subchannel data
I don't know if DVD's can have subchannel data but I guess you're right about Alcohol not offering it. Older CD-ROM drives (ex. Philips) would not create the highest quality read if you had read subchannel data enabled. I haven't seen a case where (if all the data is read properly) having "too much" correct information for the disc would make the image file worse off for mounting/emulation.the modern world:
